Ive read several threads on this topic all of which were for tightening but for removal my electric impact wont do the job.. Perhaps I need an air one but in my situation this 57 Hawk is an automatic (other suggestions were for manual which is simple)
In loosening the teeth on the ring gear are at a location disadvantage so I tried jamming wood in there to stop the crank, didnt work, I tried using the torque converter drain bolt holding it through the hole - impossible when you are just one person..
Any other suggesions? I could pull the starter but dont see how I can get leverage at that angle.
This car has A/C with a 2nd pulley which is offset about 2" out from the main pulley so it has a different bolt with a 1" head..
Perhaps an electric impact is nothing compared to an air one.. If you think that would work, That's what I'll do but not sure that will do over 80 footpounds or so needed??
