I think I figured out the problem with my '40. It has no fuel pressure at all. I guess the pump can't keep up with the engine keeping fuel in the lines, so when the engine is at high RPM it usues more gas and draines the lines until the pump refills them. (It will ONLY quit at high RPM) So I guess it needs a higher PSI fuel pump. (btw: Mine has an electric pump, not mechanical) My question is when I look for a new pump, what PSI should it have to keep the engine running? Standard 6cyl engine. (And any other suggestions)
Thanks.
Thanks.
