Does anyone know if the antenna retrac's into the body or does it stay up?
Avanti antenna
stays up about 8-10 inches..... Myers has new ones now. Be sure the base is grounded with the strap to the left rear body mount (under carpet)Bez Auto Alchemy
I bought a universal type antenna that retracts completely from Auto Zone. It fits and looks fine but I did have to run a ground wire to it since it's not made with a ground strap attachment. It may not be correct but it works fine and was less than $15.Poet...Mystic...Soldier of Fortune. As always...self-absorbed, adversarial, cocky and in general a malcontent.
Anyone installed a power antenna? Thats what I would like.
Tom'63 Avanti R1, '03 Mustang Cobra 13" front disc/98 GT rear brakes, 03 Cobra 17" wheels, GM alt, 97 Z28 leather seats, TKO 5-spd, Ported heads w/SST full flow valves.
Originally posted by jerry1 View PostDoes anyone know if the antenna retrac's into the body or does it stay up?Gary L.
Well, mine is permanently "retracted" due to a wet car cover and strong wind.
Tom,
I installed a power antenna on my Avanti back in 1978. I don't have a clue what brand it was, but it is an AM-FM w/CB. As I recall, it wasn't a big deal to install, you need to remember the ground connection for the antenna as well as the motor. Incidentally, the main reason for the power antenna was because of the car cover. Sure is convenient now. Hope this helps
Dan Miller
Auburn, GA
Dan,
Just cut a small home in the cover for the mast......no problemOriginally posted by ROADRACELARK View PostTom,
Dan Miller
Auburn, GA
Manual Antenna for the Avanti.The small '60's GM Pontiac & Chevy, don't remember their names, used an antenna mast identical in length, up or down, to the the Avanti antenna. It takes a little engineering to adapt the GM mast to the Avanti antenna base but, it can be done. Our '63 Avanti sports such a adaption. I purchased two of the GM replacement antennas years ago from a Mom & Pop radio repair shop. Went to purchase tuner cleaner, spotted the antenni hanging in their card and plastic cover. Didn't know if they were in fact the same demensions but "Pop" gave me special price just to get rid of them, I took them both.This was in the late seventies. I have a spare in case I need it at some later date.
Just as a sidebar...
My '78 Avanti II has a different approach to the radio antenna. There is no antenna mast at all. They used the stainless molding, imbeded in the rear window gasket, as a "loop" antenna. The lower connector piece on the driver's side has a machine screw through it. The antenna cable is fastened to it with a nut on the inside of the gasket. I'm not sure if/where/how it is grounded. It functions reasonably well. If you were re-doing the body and wanted to fill the existing antenna hole, the antenna mast could be eliminated, and there would be nothing to snag a cover. I doubt that anyone would notice that it was missing.
I have no idea what years this was used on. Maybe some other Avanti II owners could comment.
For my car, I found that the ultimate solution was to install a Sirius satellite radio system. Since I use the car infrequently, I installed a system with a "dock", but not a radio. I have the same dock system on my "daily driver". So, when I use the Avanti, I just pop the radio out of the Honda and dock it in the Avanti. Works great. I also discovered that there is no need to have the unsightly Sirius antenna exposed on the Avanti. Since the roof is fiberglass, I slipped the antenna between the headliner and the roof panel. The radio signal is unaffected by the roof.Jim Bradley
Lake Monticello, VA
'78 Avanti II
