Hi folks, Steve is outside tinkering with the T98 tranny in the back of the truck. He has the top off as seen in these pics . He says it seems that everything that should move does, but he can not find neutral. What needs to move to give him neutral? To refresh, this trans turns straight through like it is gear, but if he puts it in gear it locks up like it is two gears. Thanks, Tracy
help finding neutral in T 98 transmission
If anyone can give me further guidance on this please tell me what you need to see. Neither I nor a neighbor that is pretty mechanical can find anything that doesnt do what we think it should with the possible exception of the synchronizer between the 2 largest gears on the main shaft at the top. Also with the possible exception of the wear on the largest gear (which I think may be acceptable) I cant find anything that would warrant replacement in this trans. The rusty looking stuff flakes off easily and leaves a smooth gear beneath with no notable pitting. I can shoot a video if that will help. The trans in the truck is coming apart quickly. Thanks, Stevesigpic
When I changed transmissions in my '60 lark I was unable to manually turn the input shaft and hold the output shaft in neutral, there was too much friction internally. A vice grip on each end allowed me to confirm that it did indeed work.
Perhaps a piece of grit has lodged somewhere inside causing excess friction.
Originally posted by Tom B View PostWhen I changed transmissions in my '60 lark I was unable to manually turn the input shaft and hold the output shaft in neutral, there was too much friction internally. A vice grip on each end allowed me to confirm that it did indeed work.
Perhaps a piece of grit has lodged somewhere inside causing excess friction.sigpic
It probably IS in two gears at once. The lockout mechanism is located in the top shifter, so with it removed the trans can easily go into two gears at once. In the first photo, the trans is in 1st gear. In the second photo it appears to be in neutral, but it locks up because the reverse idler gear (two small gears down low at left rear of case) has slid forward into mesh. Push it back and you should be okay.Restorations by Skip Towne
Originally posted by Dwain G. View PostIt probably IS in two gears at once. The lockout mechanism is located in the top shifter, so with it removed the trans can easily go into two gears at once. In the first photo, the trans is in 1st gear. In the second photo it appears to be in neutral, but it locks up because the reverse idler gear (two small gears down low at left rear of case) has slid forward into mesh. Push it back and you should be okay.sigpic
Thanks, Goes in Monday for professional help. It looks so simplistic that I honestly think I could build it myself but looking in the shop manual all i can say is ..HUH? That being so I will pay to have this one done and try my skills on the burned up one in the truck. The shop I am taking it to quoted me $250 plus parts to rebuild it and guarantee the work. Hopefully the parts wont be terribly expensive. Thanks, Stevesigpic
$250 for labor sounds pretty reasonable, but by the time parts are involved it could come to quite a bill, if they can't save some of the rusted parts in there. The good news is, the T98 was used in such a wide variety of vehicles that parts shouldn't be a problem. I'm still betting the rollers on the input shaft are so corroded that it locked the upper shaft up.
You also need to have then check the shift detents......what others call the lockout. when these parts get worn it is possible to shift int two gears at once.If you car is ugly then it better be fast.....
65 2dr sedan
64 2dr sedan (Pinkie)
61 V8 Tcab
63 Tcab 20R powered
55 Commander Wagon
54 Champion Wagon
46 Gibson Model A
50 JD MC
45 Agricat
67 Triumph T100
66 Bultaco Matadore
Thanks guys. I replaced the shifter stuff on the trans in the truck with the one I had removed from the trans in the pics today and it fixed 90% of my problems. I felt confident that the one in the truck would be burnt up but it stays in gear now and everything looked great and was much better lubricated than I expected it to be. I still suspect it has some leaks but after looking at it I think I will have it gone through instead of this one. I am hopeful seals and maybe bearings will have it 100%. I will still fix this one for a spare or trade bait and mostly because I have to confess I still dont fully understand why its not working and I have to know. Thanks again, Stevesigpic
