Posted a while back about my '63 R1 Avanti automatic stalling out at stop lights when AC was on. Suggestion was made to get the AC Kicker from Jon Myers. I did but it won't work with my Edelbrock. Will only work with the original Carter. Is there AC Kicker that will work with Edelbrock? I turned up the timing temporarily to deal with this problem which works, but I prefer to put the timing back to where it was.
Correct AC Kicker??
Here you go.....
(copy)
Idle Compensator KIt (Maintains correct idle speed when air conditioner is on)
Includes 12-volt solenoid and mounting bracket for all Edelbrock square-bore carburetors.8059
Originally posted by Jaybot View PostPosted a while back about my '63 R1 Avanti automatic stalling out at stop lights when AC was on. Suggestion was made to get the AC Kicker from Jon Myers. I did but it won't work with my Edelbrock. Will only work with the original Carter. Is there AC Kicker that will work with Edelbrock? I turned up the timing temporarily to deal with this problem which works, but I prefer to put the timing back to where it was.HTIH (Hope The Info Helps)
Originally posted by DEEPNHOCK View PostHere you go.....
(copy)
Yes, it will work. That link is for Edelbrock Performer (AFB) and Thunder series carbs.
Originally posted by 53k View PostI have the same problem except that I have the AFB (All I have is a capped vacuum line- no kicker). Will the electric kicker work on an AFB?HTIH (Hope The Info Helps)
What do you mean...."it won't work with your Edelbrock"?? It works fine with mine..
Probably one of the best driveability 'fixes" made to the car..64 GT Hawk (K7)
1970 Avanti (R3)
