I am currently performing a complete restortation on a 62 GT Hawk and when the engine (289) was torn down, one of the cylinder walls is gouged. The pistion is in good condition and the remaining cylinders and pistons are in good shape. The engine has 123,000 miles on it. Should the cylinder be sleeved or bored and fitted with new pistions?
62 GT Hawk 289 V8
Hi, assuming that all the other cyl. do not have excessive taper and are not out of round, and that the piston skirts are not collapsed. I would think that a sleeve would be the way to go. Otherwise as you said, you would have to bore all the cyl. to the same size and puchase new pistons. Depending on how deep the gouge is would determine the amount you would have to bore. I would also be very concerned as to what caused the gouge in the first place.
Hey Bud! I don't think I've ever seen you NOT bore a cylinder, as most all of them have had over the .005" taper! BTW, the engine in my 63Avanti (that you built) is pushing 100K and still runs good!
Jim"We can't all be Heroes, Some us just need to stand on the curb and clap as they go by" Will Rogers
As of Veterans Day 2017, IHF has flown 2,450 WWII, Korean, and Vietnam Veterans to Washington DC at NO charge! to see their Memorials!
Jim, It has been a long time since I've found cylinder bores useable in any of the Studebaker engines that I've rebuilt, both 6's and 8's. Most of them have tapers in excess of .010 thousandths and I've seen bores as bad as .017 thousandths as most of the engines were equipped with cast iron rings which wear the bores much faster than moly or chrome rings. I'm glad that the Avanti engine is still running well. Bud
