View Full Version : Timing gear/chain?
curt
08-31-2006, 09:56 PM
I gather the V8 has timing gears not chains. What do you order to have parts on hand? Any 'jober' for Studebakers have a kit?
DEEPNHOCK
08-31-2006, 10:47 PM
No 'full set kit', per se...
But all the parts can be obtained from the vendors listed right here on this website...
http://www.studebakervendors.com/
For example:
Fairborn Studebaker has the aluminum cam gear and reground cams available: http://www.fairbornstudebaker.com/
Dave Thiebault makes a great billet aluminum Mallory distributor, and can rebuild your AFB and WCFB (and WW) carbs for you...
Lionel Stone has some high performance parts reproduced: http://www.studebakervendors.com/lstone.htm
Studebaker International, Myers Studebaker, Stephen Allen's Auto.. All have rings, bearings, gaskets, etc.
Your local Jobber might even be able to get all the gaskets still made by Fel-Pro (except the rear main seal kit)..
You can spend a lot of time shopping around, or you can use the resources listed right here on this site.
http://i77.photobucket.com/albums/j54/deepnhock/Jeff%20Rice%20Studebaker%20Pictures/1937StudebakerCoupeExpressJeffRicee.jpg
DEEPNHOCK at Cox.net
Ocala, FL.[u](For ONE more week!)</u>
'61 Hawk (project)
JDP
08-31-2006, 11:29 PM
The timing gear is not a typical part needing replacement even during a engine overhaul.
http://stude.com/sig.jpg
Studebaker On The Net
http://stude.com
Studebaker News Group
Arnold Md.
65 Sports Sedan
64 Daytona HT
63 R2 4 speed GT Hawk
63 GT Hawk
63 Avanti R1/AC
63 Avanti R2/4 speed
63 Daytona HT
63 Lark 2 dr.
62 Lark 2 door
62 GT(parts car)
60 Lark convert
60 Hawk
52 Starliner
51 Commander
08-31-2006, 11:33 PM
AND..... since the crankshaft gear is steel and the other one is a fibre-plastic composition (unless it's the high-performance aluminun edition), it's almost NEVER that you need to replace the steel (crankshaft) gear.;)
showbizkid
08-31-2006, 11:45 PM
So, I imagine the fibre gear should be changed out during an engine rebuild, right? :D Is there any reason to move to the billet gear for a car that's going to be just a driver?
Clark in San Diego
'63 Lark Standard
09-01-2006, 12:29 AM
Not unless you plan on keeping this car until your GRANDKIDS get it!
It was only used on Avanti and the special order HD Truck engines.
:D[^]:)
Clark in San Diego
Studebakers Northwest
Ferndale, WA
09-01-2006, 04:36 AM
The Rock Auto Parts data base shows the rear main seal as Fel-Pro part # BS100531. There used to be a pictue of it; with the two little cork pieces. The Stude venders listed probably have them; or you can order from "Rock".
Mike M.
