I put a set of flanged axles on my 54, knocked the hubs out of the drums and put it all together. Oddly enough, there was an issue (/sarcasm).
The center hole on the drum is about 3.1" diameter. The end of the axle is 2.6", leaving half an inch of slop. Makes the drum shift on braking and feels appropriately hinky.
The studs that were on the hub have shoulders that make the wheel center nicely. The studs on the axle do not, allowing slop in the axle, though the lug nuts center the wheel nicely.
Anybody know if Lark 10" rear drums will work on 54 C/K backing plates with the flanged axle? Or better yet, 65/66 flanged axle rear drums like SI has in stock?
