This is a 4V Intake valve I am just testing my forum posting skills.
4V Intake
Looks like it worked, that is a Intake Manifold for a WCFB Carter square bore 4 Brl. without the '58-'62 Coil mounts, it was used on '55-'57 Cars and all "C " Cab Trucks.
Looks much better cleaned and painted.StudeRich
WCFB cores go for $25-$75
Prepped...maybe $100
AFB (4bbl) converted from WCFB...$130
AFB Converted, prepped, and painted $150 (ask close about what prepped means)
Shipping... $30+ anywhere in the lower 48 (Fed-Ex ground)
Installation kit... with all gaskets, carb mount studs, nuts, and stainless blockoff plate(s)... $30
Depends on who you talk to...
Some do it for less, so shop around....
Originally posted by 63t-cab View PostThanks Rich,what do you think is a fair value for the painted one? actually that is two different ones side by side. the painted one is all cleaned inside and ready to go!HTIH (Hope The Info Helps)
Originally posted by 63t-cab View PostThanks Rich,what do you think is a fair value for the painted one? actually that is two different ones side by side. the painted one is all cleaned inside and ready to go!StudeRich
In cast iron, these are what I've seen.
An early WCFB (round tube choke stove)
A later style WCFB ( dual tube choke stove)
An AFB style (secondaries opened up for AFB)
In aluminum (aftermarket), I have seen (or have seen pictures of)
Offenhauser V8 4bbl early intake
Fenton V8 4 bbl early intake
Morgan Quademon 4bbl intake.
Weiand V8 4bbl early intake.
Lionel Stone 4bbl (copy of Stude cast iron AFB intake)
Bulldog prototype 4bbl intake
Erb R3 prototype 4bbl intake
I have pic's of most of them, but not on this 'puter...
JeffHTIH (Hope The Info Helps)
I was told recently that the R-1 and R-2 manifolds are different in the plenum divider area.Frank van Doorn
Omaha, Ne.
1962 GT Hawk 289 4 speed
This is a little off topic but how many different 4 bbl intakes did studebaker use?
jack vinesPackardV8
Originally posted by PackardV8 View Post/Cut/Jeff, you might add to your list the factory R3 intakes, made in both cast iron and aluminum.jack vines
But Jeff did say: the "ones he has seen"!StudeRich
Here's the Morgan...
I'll have to look in the archives at home for the others...
Originally posted by Mike Van Veghten View PostHey Jeff...can you (somehow) put pictures of the Fenton and Morgan manifolds up?
Have never heard of these two.
MikeHTIH (Hope The Info Helps)
Jim Pepper enlightened me/us over on Sonny's Racing Studebakers forum (about the plenum divider difference betweeen an R1, and R2 intake)...and why.
Originally posted by PackardV8 View PostAFAIK, the 225hp 289 4bbl AFB intake and the R1 intake are identical. The R2 has different detail in the plenum divider. Photos showing the differences were posted here a while back, but I didn't find them in a quick search.
jack vinesHTIH (Hope The Info Helps)
Any perfomance advantage with any of these on a stock 289?
I have one that looks like the ones pictured by the poster.
And possibly another that i recalled being taller with larger holes,but im not sure if it still exists.
