I became an "unofficial" truck farmer this week. I brought home a '49 2R15, a '57 Transtar Deluxe and a combination 2R5/'59 DeLuxe.
I fired up the 2R15 for a few seconds today, just to confirm that it will run. It shows 34K and is probably correct by looking it over. I'm not sure what the plan is for it right now, but I may remove the grain box and go from there.
The '57 Transtar is an E5, but the correct 185 is gone and it has a '54 champion engine with overdrive in it now. It was a good running engine, but the PO let it sit a couple years without running it and has been stuck for some time now. Not sure what the plan is on this one either, but I do have a complete V8 setup if I want to go that route.
The V8 setup brings me to the 2R/Transtar Deluxe combo. It's a 2R5 frame and cab with the '59 front clip and drive train from a 3/4 ton Deluxe. It has the '59s 289 3-speed with all the correct mounts, radiator, water housing etc for a swap into the '57. Unfortunately, the 289 suffered the same fate as the '57 and will need some work before an install.
Here's just a couple pics of them at home. I'll post progress as I get them cleaned up.
