OK, finally getting around to adjusting the clutch on the Avanti before leaving
to a car show in the next hour or so ...
I adjusted the return spring length to 10 inches as listed in the shop manual.
Second step I dont understand fully :
"Adjust the clutch pedal-to-bellcrank rod to give 1/2" clearance between the top end of the bellcrank, and the body flange of the front side of the firewall."
Body flange? I just see a hole where the rod comes through, which is just
fiberglass, no "flange" that I can see. Do they just mean the fiberglass? It
looks to be a hair over 1 inch now, and it doesnt look like there is enough
thread to shorten the rod to give only 1/2 inch.
The last step is to make the pedal travel adjustment. What IS "pedal free
travel" exactly? IS that the amount the pedal move prior to the throwout
bearing touching the clutch disc? I assume thats the case.
I am doing this because the clutch engages just about an inch off the floor
and its a little unnerving. I think the adjustment got messed up when I put
spacers under the rear engine mount to get the engine off the firewall.
Tom
Tom
