Working on a 1953 6 cylinder with overdrive. Spent the day cleaning the contacts and terminals, and running a new heavy wire to the solenoid. Went from 4.5 volts to the solenoid this morning to 6.5 volts when done. We've got the OD relay and the solenoid working by manually pulling the relay to ground
We are now getting ready to hook the throttle switch up, it came disconnected. The throttle linkage is not contacting the throttle switch when the accelerator is pushed to the floor. It appears the carburator stop is controlling the stopping point, with the linkage about 3/4" from engaging the switch. If I take the linkage off the carb, the throttle linkage will contact the switch.
Can some photos be posted of the linkage, starting with the carb, and working back, showing the idle and full throttle positions?
What also has us concerned is the bend (of the throttle linkage) going across the top of the motor appears too close to the spark plug. (Since this isn't a V8, I have no idea what I'm looking at.)
Thanks for the help.
