View Full Version : 6 volt Pertronx in a commander w/ OD
tbredehoft
04-05-2007, 03:36 PM
Has anyone had any experience with installing a Pertronix Ignitor in a V8 with a six volt system?
I bought one, it hooks one wire to the (-) side of the coil, another to the key, the other side of the coil goes to ground. (no other wires on the coil.)
Where do I put the wire from the Overdrive kickdown?
Aside from this question, the car won't start. But I'm taking that up with Pertronix.
Tom Bredehoft
'53 Commander Coupe
'60 Lark VI
'05 Legacy Ltd Wagon
Mike Van Veghten
04-05-2007, 03:47 PM
Interesting...didn't know Pertronix made a V8, 6 volt system.
Any other wires would go right back from where they originally came from. Pos. to pos. and neg. to neg. side of the coil.
garyash
04-05-2007, 06:54 PM
Here's how I wired up the Pertonix unit in a '48 M5 truck with Champ 6 engine and OD. I got the diagram from Pertronix. You need to add a 7 or 8 ohm heavy-duty resistor so that you don't short the battery to direct ground through the Pertronix unit when the OD kickdown switch is activated. The resistor had a ceramic body about 1/2" square and 3" long. I bent up a bracket from aluminum sheet about 2" wide to wrap around the square body and mounted it to the firewall.
http://www.studegarage.com/images/other/pertronix_overdrive_wiring.gif
Dartmouth, Mass.
'48 M5
'65 Wagonaire Commander
'63 Wagonaire Standard
tbredehoft
04-05-2007, 08:49 PM
Thanks, Gary, I think you've solved both of my problems.
Tom Bredehoft
'53 Commander Coupe
'60 Lark VI
