I posted this over on the Antique Stude forum under "Is an air filter really worth it at this point", but thought it might be of interest here. It's a whole different set of problems owning/maintaining the '29 than the (relative) ease of finding parts for my '48 and '52!
In working on my '29 Dictator, I'm up to the carb and it did not come to me with any type of air filter. I've only got about 4" clearance from the end of the carb. intake to the front of the starter. I could run three inches of tubing, then a 90, go under the steering box about 6", 90 towards the firewall, then 90 up and attach to the steering column some type of Air cleaner assembly there. But my title says it all - is it worth it for an 80 year old engine? What little driving I do (let's be honest - it's not going out in crummy weather, isn't driven in sandstorms, and mostly will be to town and back) with it, would it equal the time monkeying with a setup?
I'd be interested in seeing what others have done, though....
So, after several responses, but really no leads I determined a) this wasn't the original carb (hence the really, really tight fit at the air intake, and b) I was going to have to fabricate something.
I used a 90 degree silcone elbow (from a high performance parts website) off the intake to a section of muffler pipe I had bent in to a sweeping L shape that goes straight up to an air cleaner I found on a Model A/T parts website. Painted the pipe and clamped assembly as you can see to the manifold. All works really well:
