UPDATE: 6/22/2010
Wolfie/Steve called it right! Bad diaphram. I pulled the hose off carb and sucked on the hose and found NO resistance. I cut the hose 1", plugged it and pushed it on the carb tube to block air leak off the carb..
A new Echlin vacuum advance part #VC680 (Google) for my Delco distributor costs $18 at PepBoys (5 day special order) and $5 at Allied Parts (in stock)
I was told car will run but with decrease in gas mileage until I can install new part.
Thanks everyone who posted!
62 GT Hawk, 289 ran fine but now idles ok but engine doesn't rev properly. Lightly misfires and stutters, power loss.
I'm experiencing misfiring... but without the one backfire I had that may have been the reason for the blown the wire out of the condenser a few months ago.
What do you supposed caused that!? Related to my problem now?
The car fuel pump was removed and blocked. It now has Heavy duty aftermarket Carter inline fuel pump and new filters. Fuel is visible in clear filter 3 ft from carb.
The distributor was changed out 5 years ago by trusted Studebaker mechanic. Vacuum seems strong but not sure if the advance mechanism is responding, don't know how to check.
Discovered the condenser was the problem a couple months ago. The wire was blown out of the condenser. What do you supposed caused that!? Related to my problem now?
There is an electrical draw somewhere. Battery drains and is low or near dead after 5 days of sitting. Installed a green shut off on negative post.
I read somewhere to look into rewiring or doing something to the pink and green leads to coil.
I replaced the condenser and new points (gap is match cover or .17 is my guess) and things seemed to work. Rebuilt the carb due to a worn excelerator pump. I see gas is barely seeping out of the front. Can only tighten screws so much! One screw on side is not able to tighten well.
Removed Autolight plugs (less than 5000 miles on them but 5 years old) they and the .35 gaps look good. Lightly sanded and cleaned them up. One plug on passenger side #3?? or #5?? had a light tan color on the electrode ceramic.
Replaced the coil using my Avanti coil. No difference in problem.
Should I replace the 5 year old distributor rotor next? The brass has a slight play in it, a wiggle.
The 5 year old distributor cap may need to be replaced too?
Any suggestions out there?
