View Full Version : Stoopid thermostat installation question
showbizkid
04-04-2007, 06:55 PM
What's the sequence for installing a new thermostat? Is it Thermostat-Gasket-Water Neck or Gasket-Thermostat-Water Neck? I only ask because the water manifold opening is flat, but the water neck has a machined indent that the thermostat fits into perfectly.
Duhhh.... [:I]
Clark in San Diego
'63 F2/Lark Standard
bige
04-04-2007, 07:18 PM
Thermostat in the indentation so gasket to the joining surfaces are flat against each other.
ErnieR
http://i146.photobucket.com/albums/r241/AvantiR2/avnatiglamour007.jpg
sbca96
04-06-2007, 02:59 PM
Yah .. the outer diameter of the T-stat should be less than the hole
in the gasket (or there is a problem). Use Permatex No2 on each side
of the gasket and you never have to worry about it leaking again. It
only requires a thin application. Its worth it though. Use it on all
water gasket applications.
Tom
