So last year I put a rebuilt WCFB on Barney (proper Stude tag number, from a '57 President). Car runs well, idles smooth, but I have some problems.
* Poor gas mileage. Around 8.5 - 9 MPG. Engine has 400 miles on rebuild, with new coil, plugs, wires, newly rebuilt Delco distributor.
* Light but noticeable fuel smell in the passenger compartment after running at speed (say, 60 MPH on the freeway) for a period of time. Noticeable even with the windows open.
* Increasingly harder first-of-the-day starts as the weather has warmed up. In milder weather, the car starts within a couple of seconds and warms up fine; as the weather's gotten hotter, the engine will catch briefly as the starter spins, then the starter will disengage without the engine firing. Takes several tries to get going.
* After warm, engine starts easily.
* A little "poom. poom" audible in the exhaust during high-idle warmup. Not a miss, audible only from the exhaust and not in the engine room.
* If I floor the throttle, the engine bogs.
What do I need to look for? Pinholes in the fuel lines? Wrong metering rods in the carb? Mixture screws set wrong? Help is much appreciated.
