The '64 Avanti I bought last month had a cracked right side exhaust manifold. This was an aggravation since it wasn't mentioned in the eBay listing, but not a big deal. I had a manifold and the gaskets plus a new heat riser (one on the car was stuck). So, today I get the car up on jack stands and start to take off the outlet pipe. Naturally the first stud I tried snapped off. I expected that and wasn't concerned because I was replacing the manifold anyhow. But, before breaking off the other I decided to loosen the cap-screws holding the manifold to the head. I couldn't budge any of them. I was afraid to put more pressure on them because I definitely don't want to have to pull the head to deal with broken off cap-screws. I have never had cap-screws seize like that. Have I just been lucky? Any ideas on how to get them out without breaking?
I am amazed that the hog troughs, rear cross member, and frame are a good as they are because everything on this car is covered with moderate to heavy surface rust. Should have kept the California convertible- every nut and bolt on it was clean and easy to loosen.
