Need to do a quick cover up of a sun rotted rear seat back. How do you remove it?
How do you remove the rear seat back in a lark sedan?
Yes, tug the front of the seat bottom UP (maybe while trying to push back a little) - it is held down by spring-clip-like hooks. Pull that out of the way, there should (might) be screws below the back cushion holding the bottom of the seat back to the body. After they are removed, again, tug the rear straight up - there are hooks up by the package shelf. You will have to angle the back out - it is a pretty snug fit on the sides.
--george1963 Lark Daytona HT - 63V J8 175
Originally posted by doug View PostIn a '63 (yours umknown) remove the bottom cushion by pulling up at the front, and you will find the bolts that hold the back cushion.
Originally posted by gohdes View Postbolts? guess mine are missing! my seat pulls right out, and is only hanging on the hooks by package shelf. Had to crawl back there and pop open trunk when trunk lock broke! That was fun!Dylan Wills
Everett, Wa.
1961 Lark 4 door wagon
1914 Ford Model T
