63' Cruiser-289-3sp-OD-10 years outside-78K original miles-everything works-clutch stuck-undercarriage=yuck-winter beater-future 6 cyl 2dr wagon transplant.....
I've got the car in the air on stands. The T-O operating shaft is frozen on the left outer bushing (at least). Th zerk takes grease, rusty grease. The whole car is very rusty including a stuck OD cable with pulled off handle and stuck bleed screws. The clutch adjusting rod is bent (3/8th fine thread) from someone trying to force the pedal. Engine runs great, brakes are up and the exhaust is fine. 5 new F-78 tubed tires around it.....
I have the tranny ready for dropping...here comes my CASO thought. Should I simply try to loosen the shaft and once loosened, put everything back together and see how she runs.....? I do have a new T-O brg coming (THX Matt B), and will need to replace the bent rod. Or start digging into the works including new pilot brg, P-plate, disc, etc...What am I looking at roughly in costs ? Aside from my usaul sources, does anyone here have all those parts (NOS)...and do I want NOS parts (i.e. NOS asbestos). If I go the CASO route, will I likely have some operating problems, and what might they be....? THX...(I do like the new pages here)
