Earlier I posted an issue where fluid was leaking out of the pitman arm area of the power steering control valve that I resealed last year.
Last weekend I took the internals and new seals out again to make sure they are installed correctly. Everything was in the order and the seals were both facing inward as required.
Anyway, it was last year that I installed the new seal kit. I filled the system with fluid at that time and worked on other portions of the car over the next 12 months. To this day I haven't started the car yet.
So, I'm thinking that since the system hasn't seen any pressure yet that maybe the inner most seal on the pitman end was not fully seated.
Whenever I do eventually start the car, wouldn't the pressure from the fluid push each seal outward and therefore help to seal the section near where the pitman arm is?
Could this explain the leak?
Thanks, Jeff
Thanks, Jeff
