View Full Version : Oil Pan Gasket 51 Champion
cwinston
04-02-2007, 09:15 PM
I have a rather bad oil leak around the oil pan. My question is this, should I try to find a gasket kit for it or should I just use Permatex to seal it?
rockne10
04-02-2007, 10:08 PM
Gasket should be readily available from your [u]F</u>riendly [u]L</u>ocal [u]A</u>uto [u]P</u>arts [u]S</u>upply and definitely from major Stude Vendors. Are you sure it's the pan gasket leaking? Before replacing, make certain the pan flange is straight and flat.
04-02-2007, 10:12 PM
All of us Studebaker vendors at studebakervendors.com carry all the pan gasket sets, timing gear cover gasket & seal sets, rear main seals etc. that you MAY need to fix this, and yes it WILL take a pan gasket and probably some or all of the rest to fix it! [:0]
Studebakers Northwest
Ferndale, WA
