...exhaust manifolds. The '64 R-1 Avanti I bought has a crack in the right hand manifold. An Avanti right manifold is different from other Studebakers in that it has no alternator mounting boss. A left hand manifold has no mounting boss. So what is different between a left manifold and an Avanti right manifold? I have a spare set of manifolds, but the right one has the alternator mount. See where I'm going with this?
If V-8 head interchange side to side, why not...
I believe the only difference between an Avanti pass side manifold and any Stude driver's side manifold is the length of the studs, due to the heat riser valve being sandwiched in there. If you can get the studs out, you're good to go. I believe most vendors sell a "manifold repair kit" with studs for both sides, brass nuts, and three gaskets - easier than trying to get the long studs out of the cracked manifold without destroying them.
nate--
Originally posted by N8N View PostI believe the only difference between an Avanti pass side manifold and any Stude driver's side manifold is the length of the studs, due to the heat riser valve being sandwiched in there. If you can get the studs out, you're good to go. I believe most vendors sell a "manifold repair kit" with studs for both sides, brass nuts, and three gaskets - easier than trying to get the long studs out of the cracked manifold without destroying them.
natePaul Johnson, Wild and Wonderful West Virginia.
I had a broken pass side exhaust manifold on my Avanti, and an extra pass side
from a Hawk. So I had a buddy cut the Alt boss off with a bandsaw, and that is
how its been for about 10 years.
Tom'63 Avanti R1, '03 Mustang Cobra 13" front disc/98 GT rear brakes, 03 Cobra 17" wheels, GM alt, 97 Z28 leather seats, TKO 5-spd, Ported heads w/SST full flow valves.
