View Full Version : positive post on the coil
bowhawk
05-29-2010, 06:36 AM
1962 GT Hawk
I have 2 wires going into a single connector on the + post of the coil. I presume one is the resistor wire (pink). The other is green.
What is it?
41 Frank
05-29-2010, 06:50 AM
The other wire is your 12 volt current supply while cranking, this wire would come from the "I" terminal of the starter solenoid.
bowhawk
05-29-2010, 07:25 AM
Wow!! You're exactly right, but then you knew that. Probably better leave it alone.
Thanks
