View Full Version : Question about AT fluid.
63t-cab
05-28-2010, 10:08 PM
My vendor told me to use type A fluid in my Champ AT.went to the auto parts store,and guy tells me there is no more type A. but to use Dextron/or Mercon,is this what type A used to be?
2R5
05-28-2010, 10:15 PM
Thats what to use , if you look on the jug somewhere it will mention what it replaces.
rockne10
05-28-2010, 10:31 PM
Dexron/Mercon is simply a better formula for the application than was available at the time. It won't disappoint you. My '51 DG200 originally called for 10W oil. Fluid engineering has improved and our old automatic transmissions have benefited from the science.
05-28-2010, 11:17 PM
As has been said, the Dextron/Mercon will work OK. That said:
Many, probably MOST of us figure that being a Borg Warner Flight-O-Matic which is the same as a Ford-O-Matic, it just makes sense to use the preferred Fluid for pre-1968 Fords. The type "F" (now being reproduced by Valvoline) produces the FIRM type of shifts that I happen to prefer as apposed to the GM method of a slight slip and slide produced by the Dextron.
Type "A" was speciified for use in Studebakers and Fords, for Auto. Transmissions, Power Steering, and Superchargers, so since Type "F" is the preferred replacement for "A", there is never any reason to use anything else but Type "F" anywhere in a Stude. :)
okc63avanti
05-28-2010, 11:33 PM
The Avanti workshop manual also specifies Type "A" ATF for lubricating the Paxton supercharger. I would use the Valvoline Type "F" for the supercharger and not the Dextron ATF which as stated above is slippery.
studefan
05-29-2010, 07:45 AM
What should I use for the power steering on my 64 lark? Book says Type A, but can't find it at the parts stores.
I was told NOT to use today's clear power steering fluid but to use automatic transmission fluid in the power steering system. Should I use the Dextron/Mercon for this application?
BobPalma
05-29-2010, 08:07 AM
Yes; Dexron/Mercon or equivalent. BP
raprice
05-29-2010, 10:51 AM
I've been using Type F in my '59 Lark VI. I was convinced I should use this after I attended a tech session at one of the Int'l Meets in South Bend. Your question was asked by yours truly and that was the answer.
I agree with StudeRich that, since it's a Borg Warner trans and similar to Fordomatic, it makes sense to use Type F.
I also agree that the shifts are crisper and I like that.
Rog
53k
05-29-2010, 01:10 PM
Sometimes you find Type A in dollar-type stores, but DO NOT use it. It may be nothing more than colored kerosene.
barnlark
05-29-2010, 02:44 PM
Has anyone tried any of the synthetic transmission fluids in a FOM? Any problems? I'm about to try that after a fresh rebuild and just wondered. My trans shop didn't have a problem using synthetics, but suggested keeping up with a more thorough transmission service/ fluid replacement routine and it would balance out price-wise.
avantilover
05-30-2010, 01:23 AM
Checking the account I got from my last Transmission service, they used 4.80Liters of Valvoline TQ-Dexron iii ATF, next suggested service at 45,000Miles am now at 34,000M. Fascinating to consider these transmissions are still going strong after nearly 50 years - shop said the latest Audi's BMW's etc suffer gearbox failure after 60,000KM 36,000M. Owner said "they pay AUD$180,000 for a BMW and the gearbox fails after 60,000KM." Am sure I'd be unimpressed. Too many damned computers nowadays - been having trouble with my Focus and it eventually turned out to be a faulty steering sensor in the steering wheel, when it fails it screws up the transmission shifts.
Warren Webb
05-30-2010, 03:00 AM
I tried synthetic power steering fluid in my Hawk. Afterwards the control valve started leaking really bad, so bad that it leaves a trail of oil on the ground. Needless to say, I'm not driving the Hawk now, at least until I am able to rebuild the control valve.
rockinhawk
05-30-2010, 08:53 AM
I agree with Rich on the type F. I recently replaced the Trans in the wife's GT with a used one from a parts car. AllI did was clean it up,service it and install it. As advised, I put Dextron III. It leaked badly, shifted poorly, and slipped a little. My plan was to have the original trans rebuilt and put it back in. I consulted with a transmission man who told me to drain the dextron, and refill with Type F. I did and IT WORKED!! Still does. NT
63r2
05-30-2010, 08:19 PM
I have been wondering the same thing.
I have an R2 Avanti and it would seem sensible to use one fluid type in the Supercharger,Auto and Power steering.
As type F was recommended for the Supercharger it appears I can use it on the others as well.
pb
