can't start without ether anyway.
Ive got a fresh Carter AS 3370S ('62 Lark application) on the truck, which was running OK with it's old RBS, only the carb was changed. If I set the choke to 1 notch lean, it will start, but immediately load up and run very rich. If I set the choke to 5 notches lean so it runs fine immediately after starting, it won't start the next morning without either re-setting the choke or a light squirt of ether. Even the RBS was better than this, does anyone have any ideas?
