Does this sound familiar to any of you? You have an old Studebaker, and you'd like to not worry about being caught out in the rain, and/or you just want to have windshield wipers on the car to maintain some semblance of legality. But, you don't like the look of ugly aftermarket wiper blades, so either you kept the original stainless Trico blades which amazingly enough are still on the car, or else you went to York or Reedsville and bought some used wiper blades from one of the parts vendors, figuring you'd put new rubber in them. Unfortunately, finding refills of any kind in a parts store is difficult these days. Here's what works:
If you have a 63-up Lark or Avanti with the 15" wiper blades, and the blades still have the original splines and clips intact, get yourself a set of Trico part no. 43-190, 43-200, or 43-220 refills (you probably will have to order them.) They are long refills but have a spline somewhat similar to the original stainless Trico blades used on our cars. (I was hoping that it would be *so* close that it could be cut down and modified to work in case you had an original blade with non-original spline, but no such luck.) I bought some CarQuest 453-190 refills, which I believe are just a relabel of the Trico 43-190. There was a little dot of glue holding the rubber into the spline, I just broke that with my thumbnail, pulled the rubber out of the spline, and scraped as much as I could off. Then I cut the rubber to length with a razor blade (for a 15" blade, looks like it should be somewhere around 14-5/8" to 14-3/4") removed the original spline from the wiper blade, pulled the rubber into the original spline, and reinstalled. Looks close enough to original from any farther away than a foot or two to fool anyone but a Bloomington Gold show judge, and is the easiest solution I've found to keeping your original wiper blades yet.
I suspect but don't have an example handy to test that this will also work for the 12" blades used on all 56-62 cars and 63-64 Hawks. This would be fantastic if it did as those original Trico blades were never intended to be refilled so your only other options are to remove the original splines and use a universal plastic spline refill modified to fit or else pay $20-something plus S&H for show-correct repro rubber inserts from one of the Corvette parts suppliers (what's on my car now, but when those wear out...)
For the 15" blades, a Trico 43-150 will fit and function, but the spline is not as original and it does bind somewhat as the rubber above the spline is a little larger, so I suspect that using the longer refill with the correct profile extrusion with the original spline as I have described above is preferable, assuming that you still have the original spline and clip.
So don't throw out those original wiper blades, shine 'em up and refill them. If you see a parts car with original blades, grab 'em! Please don't let another nice looking Studebaker fall victim to the Ugly Black Wiper Blade syndrome!
good luck
good luck
Unless of course, someone makes me an offer I can't refuse in Glendale next week!
