I have original style umbrella seals made from Viton which are supposed to last longer than original rubber. I also have a type that holds the seal tightly around the guide and the valve stem by means of a small spring clip on both ends of the seal. I'm sure the spring clip style would seal better but would it be better to use the original style so the valve guides would get some lubrication.
I have new guides and valves and was thinking of using some STP on the valve stems prior to assembly. Would there be a better lubricating product to use for this area?
regards,
Jay
regards,
Jay
