I just replaced the power steering cylinder and now, with the front of the 62 GT Hawk off the ground and supported on jack stands, the wheels creep to the right. If I attempt to turn the the steering wheel, from a center position, the wheels imediately swing hard to the right and oscillate violently until I turn the engine off. The power steering fluid is topped off and there only appears to be a very small leak at the lower hose connection to the cylinder. What should I be looking for? If the power steering system needs bleeding how do I do that?
Power Steering problem
Are you certain that you have the hoses hooked up to the correct ports on the ram and the control valve? I think somewhere on Bob Johnstone's site is an article with photos showing the correct connections. It'd be pretty easy to get them mixed up at the control valve as there's three connections very close together.
nate--
