View Full Version : Vacuum wipers
Kdancy
03-29-2007, 05:29 AM
I am working on a 1955 Champion with vacuum wipers. Can I change over
to a later 12 volt wiper motor fairly easily?
53commander HDTP
53 Champion HDTP
61 Cursed Purple Hawk
64 Champ long bed V8
50starlite
03-29-2007, 09:01 AM
YOU DRIVE YOUR STUDEBAKER IN THE RAIN!!?;)
Really though, I got caught in an unexpected downpour yesterday and they worked just fine, once I found a place to pull over and stop.
Dick
Mountain Home, AR
http://livingintheozarks.com/studebaker.htm
N8N
03-29-2007, 09:39 AM
I would assume so, I would think that you would need an electric motor from a 53-55 sedan and the matching switch (or 56-60 if you have converted to 12V; the early switch works fine on 12V)
Harv
04-01-2007, 11:10 PM
The vacuum wipers are my '50 Starlight really suck so I tried a few things. Went to a double sided fuel pump. It worked a bit better. Used some teflon spray on the inside case of the wiper motor where the flapper rides. Worked a bit better. Best bet was to use rain-x. It worked great. Bugs have as hard a time sticking to the windshield as the rain does. Options: Move to the dry flat-lands! [8D]
StudeBakerHarv
