View Full Version : Slow fuel filling
terrymb
03-28-2007, 09:52 PM
My 52 Commander is very slow to accept fuel. The gas fills up in the neck and the pump shuts off. I have to fill it very slowly. Could the hose be collapsed? I'll check the hose, but was wondering if there is anything else to check for? I thought gas tanks had a pressure release valve or something but I didn't see one in the chassis manual.
Thanks,
Terry
1952 Commander Starlight
rockne10
03-28-2007, 10:04 PM
No pressure valves or vents in the '52. I would think the hose has collapsed. Another possibility is someone has replaced the original hose with an aftermarket straight piece. There is a slight bend in the original hose which is available from Studebaker vendors (part#531581). If you try to use a straight piece it will immediately restrict itself.
Brad Johnson
http://i57.photobucket.com/albums/g233/rockne10/51x2.jpg'33 Rockne 10, '51 Commander Starlight, '53 Commander Starlight
terrymb
03-28-2007, 10:12 PM
Thanks Brad, I'll check tomorrow. Actually got to drive my car this weekend. Had temps in the 70s, 30 degrees above normal! I got the car last fall and only got to drive it about 5 total miles. Had a bunch of work done over the winter and was very anxious to drive it long enough to at least charge the battery.
StudeDave57
03-28-2007, 10:27 PM
OH, yes those silly 'vapor capture boots'...
Just one more reason I won't look back when I leave this State~
Thank goodness there are still places you can go that DO NOT use them!!! :)
StudeDave [8D]
studeclunker
03-28-2007, 11:04 PM
Another problem you will find, is the rubber pipe section will give if your station has the capture boots on the filler nozzels. The really stiff ones can cause problems with the flexible pipe section, sometimes damaging them. My '62 Champ has this problem. I have to hold the boot back and sloooooooly fill it.
http://i16.photobucket.com/albums/b18/Studeclunker/december%2006/HPIM0234.jpg http://i16.photobucket.com/albums/b18/Studeclunker/56%20Parkview%20Wagon/56wagonleftfrontclipped-1.jpg
Home of the famous Mr. Ed!
Lotsa Larks!
Ron Smith
studeclunker
03-29-2007, 01:07 AM
Yes, Dave, I have to agree, vapour capture boots are just the least of the things I won't miss if I ever escape California.
Lotsa Larks!
Ron Smith
