View Full Version : 259 Oil Pan
CTLark
03-28-2007, 06:39 PM
Does anyone know where I can get an oil pan for a '63 Lark with a 259 engine?
03-28-2007, 09:10 PM
Are you looking for new or used? New (NOS) is probably next to non-existant. Useable should be fairly easy.
Miscreant adrift in
the BerStuda Triangle
03-28-2007, 09:33 PM
You need to order a 1539382 '56-'57 V-8 will work, or a '58-'64 (all V-8's) 1547193 with smaller 3/8" drain plug. Check the vendors at studebakervendors.com
I didn't find one at SASCO.
Studebakers Northwest
Ferndale, WA
CTLark
03-28-2007, 10:04 PM
Used is fine, the one on my Lark is quite rusty probably from sitting for 19 years in previous owner's garage.
03-29-2007, 02:09 PM
ANY I might have are gonna be "rusty" to a degree. Rusty can be dealt with thru chemically cleaning or by bead-blasting (Althought I don't LIKE bead-blasting engine parts too much because I worry about the glass beads hiding and coming out to "play" when the engine heats up!)
As long as your's isn't rusted THROUGH - it should be perfectly serviceable.;)
Miscreant adrift in
Transtar60
03-29-2007, 04:24 PM
Biggs internal engine stuff they make walnut hull media to blast with
http://racingstudebakers.com/coppermine/albums/userpics/10056/5E13%20Pic%203.JPG
3E38
4E2
4E28
5E13
7E7
8E7
8E12
8E28
4E2
59 Lark
etc
03-29-2007, 04:32 PM
Can I pour some in my crankcase, Charlie?;) I've got a box of it here.
Miscreant adrift in
