View Full Version : motor & transmission match
DWard
03-28-2007, 12:18 PM
I HAVE A 1957 SILVER HAWK WITH A FLATHEAD 6 AND A 3 SPEED AUTO TRANSMISSION. WILL A STUDE 289 BOLT AND WORK WITH THAT TRANS???
THANKS!---DAN
gordr
03-28-2007, 12:46 PM
THANKS!---DAN
I believe that the bellhousings are different. Find a 289 with an auto tranny bellhousing and torque convertor, and it ought to work. I think the 6 cylinder tranny is first-gear start, and the V8 tranny normally starts in second, but it ought to work, nevertheless. Stude automatics have a separate bellhousing; just undo the 4 big bolts, and carefully withdraw the input shaft from the convertor. Needless to say, one has to ensure the drive tangs for the front pump are correctly aligned to re-install.
BTW, a 259 will also work fine, and you ought to be able to easily find find a 259+auto from a rusty Lark donor car. You will want the throttle valve linkage for the tranny, too.
JDP
03-28-2007, 12:57 PM
The six cylinder transmission will not work with a V8. I've found the best way to do the swap is to buy a rust bucket V8 parts car. You'll need enough parts that'll it be easier and cheaper in the long run to get the V8 engine/trans/rear, drive shaft, brakes and the rest from a donor car.
64 Commander 2 dr.
64 GT Hawk R2 clone
64 Daytona HT
63 R2 4 speed GT Hawk
63 Avanti R1
63 Daytona convert
63 Lark 2 door
63 Lark 2 door #2
62 Lark 2 door
60 Lark HT
60 Hawk
59 3E truck
52 Starliner
51 Commander
