View Full Version : 12 volt conversion on 1950 champ
gotti210
10-17-2004, 12:37 PM
what all does the process consist of
i understand that i need to purchase a 12v internal reg alternator & change out all the bulbs in the car -
but what all do i change to make guages, switches, OD and other ness work [?]
Sonny
10-17-2004, 01:36 PM
Switches will be be OK, you'll have to put a resistor block in to drop the voltage to the points, the gauges will be OK as long as the instrument transformer is good, except that the wires for the voltage gauge will have to be switched or it will read backwards, (you are gonna change it over from a positive ground right?), and I'm pretty sure the OD setup should work OK with 12 volts, but mebbe somebody else can address that one. The starter will work too, BUT, no prolonged turning of the engine or you can burn it up.
I know that this may not be the way you wanna go, but I've had VERY good luck with just putting in an 8 volt battery and not changing anything other than putting a resistor block in for the points and tweaking the regulator so the generator will charge the battery.
Sonny
http://RacingStudebakers.com
Chris Pile
Why not just install a 6V Pos. Ground Alternator? It's the simplest way to get your Stude's electrical system dependable for less than $100. One wire GM style alternator's are available, and easily installed. The regulator is built in, and no bulb or belt replacements are necessary. Contact me for more info. - Chris Pile
gotti210
10-17-2004, 01:49 PM
im wanting 12 volts cause its gonna be street rodded
stereo system, power windows, shaved handles [door poppers], retractable license plate ect.
Sonny
10-17-2004, 01:53 PM
OK, got-cha. Yep, you'll need 12 volts
Sonny
bing kunzig
12-13-2004, 12:35 PM
regarding the 8 volt battery suggestion, what does "tweak the regulator" mean?
Bing Kunzig
new member
Sonny
12-13-2004, 12:56 PM
Bing Kunzig
new member
"Tweaking" the regulator means setting the 6 volt regulator voltage up a little bit so the 6 volt generator will charge the 8 volt battery properly. You should let an auto electrical shop do it for you though. Depending upon what type of regulator that you have, (screw or "bent arm" type adjustment), it can be a PITA to set it yourself. If the shop does it, they put it on a machine and can adjust it right on the money to what we've found that works pretty good, from about 8.9 to 9.2 volts, (NOT too much more, at least not from a 6 volt generator). It will charge the 8 volt battery but it won't overheat the generator at those voltages.
Sonny
12-13-2004, 02:30 PM
Gotti,
Going 12 volts is not that hard. There's the bulbs as you mentioned and of course, the charging circuit and all that's associated therein.:)
The insturments you can get by with by buying a regulator from a hot rod supplier. There's several to choose from. As Sonny said, you may have to swap polarity of the gages themselves to get proper readings. (This because you're going from Positive ground with the 6volt to Negative ground with the 12volt system)[:0]
Additionally, if your Champion has a heater and defroster (quite a few didn't) those motors will have to be changed out as well as the W/S wiper motor - assuming it's electric. The heater/defroster motors (Studebaker called the conglomerate system: "Climatizer")- assuming you change them to 12volt motors - will not respond to the low-speed resistors of the switches as well but that's kinda minor and said resistors could be changed for those of more suitable values if desired.
I've heard that the OD solenoid will go some time on 12 volts. I don't know that from first-hand experience but I'd be suspect about such claims. A 12volt solenoid of the same function and configuration should be fairly easy to find as well as an OD relay for 12volts.
If you're Champion is lucky enough to have come with original turn signals, you'd have to find a flasher to change out as well. Should be easy to do that.;)
I'd say that the W/S wiper motor should be the biggest challenge to overcome as the '50 had the system of cables and pulleys and unlike the vastly changed setup of '51, there's no simple bolt-on upgrade for the 50.[8)]
Oh - you didn't SAY, but I might assume that you're planning on keeping the Studebaker engine and tranny[?]
conestogaman
12-14-2004, 11:27 AM
I did a 12V swap on a VW a while back (6V neg grnd) and found this: The wiper will work, except it'll be extremely fast. I just put in a delay to slow it down. It was still fast, but it'd turn off after 1 wipe so it wasn't whipping the blades off. Perhaps switching the polarity and using a resistor will work for you.
The starter is ok as long as you keep cranking to about 15 seconds or less (as stated earlier). I didn't put in the guage resister and found that the fuel guage read a bit high. I didn't worry about it as I relied on mileage for refuel anyway.
The usual bulbs, horns etc.
Wheels down, shiney side up, drive it like you stole it!
bing kunzig
12-15-2004, 02:48 PM
who makes 8 volt batteries?
bing kunzig
12-15-2004, 02:50 PM
Sonny
12-15-2004, 03:22 PM
Just about anywhere. A place like "Tractor Supply" especially. I've even seen them at Sears.
Sonny
bing kunzig
12-15-2004, 05:45 PM
There is also the option of a 6/12 volt battery. How does that compare to an 8 volt set up?
1950Champ
01-04-2007, 01:46 AM
You Shouldn't have to worry about the windsheild wiper motor, as in a 1950, if original, it should be a vacuum motor, and not need adapting.
Spence
John Kirchhoff
01-04-2007, 09:52 AM
Running 12 volts through a six volt starter will definately perk things up. The field coils are much heavier on the 6 volt, so 12 volts won't hurt anything. At www.fifthaveinternetgarage.com you can find Runtz voltage drops for the instruments. What's neat about them is that instead of using a resistor to cut the voltage, they use a transistor. The latter will provide a much more accurate and steady voltage and won't produce heat like the resistor will. It looks like you'll need two, one for the fuel gauge and for the temperature guage. As has been mentioned previously, just swap the ammeter leads side for side. The same outfit makes conventional reistors to drop the voltage for the heater and defroster motors and wipers if so equiped. Best of all, with 12 volts you can use decent halogen headlights and see where you're going. If your car's wiring is ok now and not frayed, corroded and so on, it'll be fine for 12 volts. Double the voltage, cut the amperage in half and it's the amperage that creates heat.
CHAMP
01-04-2007, 10:14 AM
Gotti, They just outlawed the retractable license here in Maryland. They can ticket you while setting at a show if they want to. It seems the law reads the license plate must be displayed at all times.
Original50
01-04-2007, 06:23 PM
The fuel guage is geared to operate on 5 volts, and you are running 12 volts into the thing? The gas tank sending unit see's 12 volts instead of 5 volts? You are literally playing with fire there, my friend. That is why most 12 volt fuel guages has a limiter in the thing to drop the voltage down to 5 volts and that 5 volts is applied to the temperature guage. On the 50 Champion the oil guage gets it go juice from the oil pressure itself instead of the bio-metallic heat up thingie in the guages. It would be wise to disconnect the fuel guage if you don't want to see an explosion in your fuel tank. A sixty amp 12 volt battery can generate quite a spark under conditions you don't want to witness.
Don Dodson
Studebayker
01-04-2007, 08:07 PM
I just tapped the 12v battery in the Stude when I installed a C@%y
in it back in 1960. I only ran the engine off 12v, and the rest off
the tap. I did change the polarity in the car, even the OD worked.
James K. Clark
East Tenn.
'55 Prez. 2dr hdtp.
Don't take yourself too seroiusly!
James K. Clark
rockne10
01-04-2007, 09:31 PM
quote:Posted - 09/13/2006 : 9:31:38 PM
The editor and technical advisors (Bob Palma and Dwain Grindinger, respectively) of The Studebaker Co-operator column in Turning Wheels are both regulars here and, while they stress 12-volt conversion should only be desirable if you want A/C and 50,000 watts of stereo (a well maintained 6-volt system works as it should), they both endorse Randy Rundle's The Official 12-volt Conversion Guide for $10 to Fifth Avenue Antique Auto Parts, 415 Court Street, Clay Center, Kansas 67432
John Kirchhoff
01-05-2007, 10:45 AM
The voltage drops will make your fuel guage operate correctly. The reason all fuel gauges operate at less than battery voltage is so the meter has a steady voltage regardless of what the generator-alternator voltage is. A fuel guage on a 6 volt systems runs on 5 volts because in operation, the system voltage could vary from approximately 5.5-8.2 volts. I think gauges on 12 volt systems (at least on older Chryslers) ran at 7 volts because the voltage on that system could run from 11.5-14.5 volts. By using a voltage drop,you won't have to change the sending unit in the tank because normally 6 and 12 volt systems have different resistance values. Swap them and the guage will never be accurate. I don't think you have to worry about anything blowing up though, heck, now days they put little whirring fuel pumps in gas tanks.
Original50
01-05-2007, 04:23 PM
I hate it when this happens. I try to inform a person who obviously is unaware of his mistake, and I have to argue with someone. My background in Electronics lets me have some mention of knowing what I am talking about if I may. Trained by the U.S Navy with extensive Electronic theory back in 1963 through 1965, and put that training to work on a Guided Missle Frigate. Out of the Navy I was a Support Curstomer Engineer with IBM for 28 years. YES an explosion can occur with his hook up. The sending unit has no resistance from the battery to the coil of wire on the sending unit. That coil of wire is a resostat of variable resistor. The battery is capable of providing 60 amps of current to the sending unit, with no questions asked as it does so. To get a spark, all that is needed is for the wiper arm in the sending unit to bounce from a piece of trash that the wiper arm can run into and that bounce can lift the wiper away from coil of wire and we have a spark in the making, and BLEUIE!!!
On a twelve volt car the alternator or generator will put out 14.4 to 14.7 volts with the engine running and with the engine running the deciding factor will then be whatever the generator or alternator will put out in current. I have a Chrysler type vehicle which is a 1967 Dodge Charger, and "Ole Red" puts out 14.7 volts from the alternator, and the limiter on the fuel guage limits the voltage and current to the tempature guage and oil guage to 5 volts. On a 12 volt system, the sending unit is restricted in the amount of current it can handle via the limiter in the fuel guage as it presents the 5 volts to the sending unit. With he way this youngster has his sending unit hooked up from my observations of this thread, there are NO restrictiions to the current flow. It is the same as running the sending unit straight to the battery. I've gat a feeling that coil of wire in the gas tank will heat up with 60 amps pushing the thing. Yep, I stand behind my comment about disconnecting the sending unit until he can make sure everything is hunky dory. As for pumps at the rear of the cars providing fuel under pressure is another matter, with different conditions at the helm.
http://www.netcase.com/images/charger_stuff/67redcharger_icon.gif
Don Dodson
John Kirchhoff
01-05-2007, 08:23 PM
Don, believe me, I'm in no way arguing with you or underestimating your expertise. I have experience with electronics also, but no where close to yours and I'm the first to admit that. But when it comes to mechanics and electrical systems, I'm no inexperienced dummy either. I've had years of hands on experience with 6, 12, and 24 volt electrical systems on every sort of motorized machine you can think of, except maybe something out of the ordinary like a tank or locomotive. In addition I do household and farm wiring and nothing's burned down yet, so I must be doing something right.
As you know, for gasoline to explode, the air-fuel ratio has to be within rather narrow parameters. Many sending units have the resistance unit located near the bottom of the tank. When it's submerged in fuel, it's not going to explode no matter what happens. If the air space in the tank is too fuel rich, neither will it explode regardless of how many sparks are bouncing about. Besides, a spark is a spark and a flammable mixture doesn't care whether it's generated by 6 volts, 12 volts, a flashlight battery, 20,000 V ignition coil or megawatt high tension lines.
I do disagree on several points however, and please don't take this personally because it's not meant that way. As far as getting a spark from the wiper on the sending unit, I straddled a 5 gallon gas tank on my motorcycle for 30,000 mile with a sending unit that was loose as a goose. When I repaired, not repalced it, I found it was just excessive wear that allowed the wiper to bounce around making my gauge needle sway to and fro like a hula dancer. Apparently there were't any deadly sparks produced because if so, I wouldn't be writing this now.
Your statement about the battery providing 60 amps to the sending unit is rather optomistic. True, a battery could spew out 60 amps easily, but there's no way to get 60 amps through the sending unit wiring, or hardly any other wiring under the dash without something suffering a meltdown. I'm not sure what gauge the wire to the sending unit is, but if it's 12 guage, it'll carry a maximum of 25 amps and if 16 gauge, 13 amps. Those numbers aren't a product of my wild imagination; I looked them up in the "Ace Pocket Ref" by Thomas J Glover. 60 amps through the wiring would have something going up in smoke.
Please believe me when I say I'm not arguing with you. I know you were as you put it "trying to inform someone unaware of their mistake" and you should be commended for that. To me there is no greater good than helping someone and expecting nothing in return, which I fully believe describes you. However, we should all try to make sure our information is as accurate as possible because some folks don't know the difference. Hey, I've made mistakes on here and have been corrected by others for which I appreciate. No one was trying to "argue" with me, just correcting me. A while back I pointed out a mistake I'd made on an earlier post with no prompting from anyone. I was wrong and sure didn't want anyone getting screwed up because of my oversight. So friend, whether we agree or not, I'll discuss anything with you but I won't argue with you. I'd be doing a disservice to you, myself and everyone else.
ghcoe
05-04-2007, 01:02 PM
I have a 1951 Commander that I want to convert to 12 volt system. Was this system originally a positive ground? Were all Studebaker 6 volt systems positive ground. Haven't put a battery in it yet, but need to know before I do. Thanks, ghcoe.
gordr
05-04-2007, 02:07 PM
Studebaker gages are "thermo" gages. I've taken them apart. The pointer is connected to a pair of thin bimetallic strips, which will bend when heated. Around each of these strips is wound a fine coil of resistance wire. The wire is not much thicker than a human hair. Source voltage (6 or 12 as the case may be) enters the gage at one stud on the back, and is fed to one end of each coil. One coil has its other end connected to the sending unit, and the other has its other end grounded. The coil connected to the sending unit acts to move the gage pointer towards "full", and the other coil acts to move the pointer towards "empty". The only influences on the strength of that coil's "push" are system voltage, and ambient temperature. The coil connected to the sending unit is influenced by both those factors, PLUS the resistance of the sending unit. Since the two coils oppose one another, the effects of system voltage and ambient temperature are cancelled out, and the movement of the pointer is solely the function of sending unit resistance. Neat, huh? There is no voltage reducer used in any Studebaker instruments that I have seen. The resistances of the gage elements themselves and the sending unit are chosen to work well with the range of system voltage in the car they are designed for.
Now some brands of cars do indeed use a voltage reducer for the gages; the idea is to regulate to a lower voltage so that the gages don't reflect slight changes in system voltage due to engine RPM and electrical loads. The regulators that I have seen, and opened up, BTW, are pretty much akin to a signal flasher unit: they contain a bimetal strip wrapped with a heating element, and movement of the strip opens and closes a pair of contacts. Contacts closed: a full 12 volts gets through. Contacts open: zero volts get through. A nine-volt regulator would be designed to have its contacts closed 75% of the time, given a 12 volt source. My friend Charlie, the Volvo guru, calls these things "boingers" because of the faint "boing" sound they make when cycling, which they do a few time per minute.
In any case, the purpose of the regulator is accuracy of the gage; it is not intended to prevent fires by limiting current through the sending unit. The resistance of the gage element itself will limit the current through the sending unit to a very small value.
In any case, if you look at a fuel tank sending unit, you'll note that the resistance element is contained within a steel shell, with small openings for the float arm. That is the safety feature which prevents a spark from igniting the atmosphere inside the tank. A fire which occurs within the sending unit will be quenched before it can pass through the small holes in the shell. Look up "Davy lamp" in a search engine.
Mr. Dodson, despite his obvious qualifications, has dumped a load of misinformation on this thread. To get back to the OP's question, I'd second Rockne10's suggestion to pick up Randy Rundle's book.
