View Full Version : 66 engine swap
nc66
08-13-2006, 08:04 PM
I've got a 66 cruiser with a bad engine and my question is about putting a 230 in place of the 283. It just doesn't look like there is enough room without moving the radiator forward. Did the engine get moved back or was there a different radiator?
r1lark
08-13-2006, 09:55 PM
IIRC, the radiator was actually moved forward to make room for the longer six cylinder, by using a different panel behind the grille (the panel that the hood latch bolts to).
Do you have a parts book? If so, you should be able to verify this. If not, let me know and I can check mine.
Where are you located?
Paul
Visit The Studebaker Skytop Registry website at: http://hometown.aol.com/r1skytop/myhomepage/index.html
nc66
08-13-2006, 10:25 PM
what's happening Paul it's Mike Teague here. you got a 65chassis manual?
8E45E
08-13-2006, 10:36 PM
[quote]Originally posted by nc66
Indeed, the radiator does sit a few inches farther forward in a 6 than it does on the V8's. You will have to located a rad saddle and the sheet metal spacer from a '65-6 6-cylinder to make it fit.
Craig.
sbca96
08-14-2006, 02:06 AM
You will kill the value by putting a 6 into a V8 car. With the cost
of a running GM V8 at less then 500 bucks, just get another V8. If
you are in Southern California, I have a running 305 Chevy that you
can have for a couple hundred - you pick up! (I will throw in the 350
transmission for free!)
Tom
Scott
08-14-2006, 10:13 AM
nc66, I'm selling my 66 Cruiser and it runs well and doesn't look too bad. I've got new fenders and front valance and other parts. It does need some floor work and a few other things things, but it's already a driver. I'm in MN. Since these pictures the wheels have all been repainted white, like the originals. I'm asking $2000 for everything. Maybe that would save you the trouble with yours. Plus mine has NOS kingpins installed and disc brakes.
http://static.flickr.com/49/141588685_4995aeee2e.jpg?v=0
http://static.flickr.com/49/141588688_b4d2280dff.jpg?v=0
I'm only selling it because I decided to get a older VW bug as a winter driver and something has to go to pay for it.:(
imported_n/a
08-14-2006, 10:27 AM
I'd forget about switching to the inline six, and use a 305 like sbca suggested.
sbca96
08-14-2006, 12:21 PM
If you are on a budget .. if you have some extra cash, and want to do
it "right" then I would rebuild the 283. Its a good engine, with a
few upgrades that the factory GM's didnt get. Or you can pick up a
350 engine locally. There are a LOT of options with the GM powered
65-66 models. I'd be tempted to drop in an LT1 or LS2 crate motor!:D
Tom
