View Full Version : 63 289 engine
mtdoraford
03-26-2007, 09:24 AM
Can anyone help? Is the 289 Stude block and heads an early representation of a ford 289 or chevy 327, or is of no comparison. If you were looking to buy aftermarket, compressor/alternator brackets, any idea of all that are listed, which ones to buy? Thanks for the insight.[:p]
klifton1
03-26-2007, 09:52 AM
Studebaker engines are not the same as Chev or Ford. Parts don't interchange. No comparison.
Klif
55 Speedster
42 Champ Coupe
64V-K7
03-26-2007, 09:53 AM
Read this 1000X.....
Other than being a V-8, a Stude 289 is NOT a ford (or chevy), in any way, shape or form.
If you buy an aftermarket compressor, the only viable option is a Sanden rotary and they have mount tabs on 8 corners, so you shouldn't have any trouble mounting it.
If you have an old generator bracket and a drill, you can mount a Delco alternator without a problem. Probably other ones too, but I only use the cheap stuff.
Bob Johnstone
http://www.studebaker-info.org/7168422/sig2.jpg
JDP
03-26-2007, 10:23 AM
Vintage Air sells two styles of brackets, the crank pulley, or the entire AC kit. You can also add the Studebaker parts found on ebay quite often. Vintage Air also sells the Sanden to Studebaker adapter.
64 Commander 2 dr.
64 GT Hawk R2 clone
64 Daytona HT
63 R2 4 speed GT Hawk
63 Avanti R1
63 Daytona convert
63 Lark 2 door
63 Lark 2 door #2
62 Lark 2 door
60 Lark HT
60 Hawk
59 3E truck
52 Starliner
51 Commander
03-26-2007, 11:32 AM
Our own forum member (railway) has mounts and whatnot to put AC on a Stude as well.:D
Miscreant adrift in
the BerStuda Triangle
53k
03-26-2007, 03:28 PM
And, he is good to deal with (helpful, knowledgable). I just bought a complete setup from him. I might have gotten it cheaper directly from Vintage Air (and maybe not), but I wanted to be sure I had everything I needed. The evaporator looks a bit like the '64 factory unit, but is more compact.
Museum R-4 engine
03-26-2007, 08:20 PM
Let's not forget that railway (Ebon) is a Stude guy, thru and thru. He and his dad both!;)
Miscreant adrift in
