View Full Version : .20/20 ?
dclewallen
07-15-2006, 06:11 PM
I have the opportunity to purchase a 289 crankshaft thats already been turned .10/.10 but will need to be turned again to be usable. Is there any problem with this on a Studebaker crankshaft? Thanks,
Darryl C. Lewallen Clarkesville, Ga.
ROADRACELARK
07-15-2006, 06:33 PM
Darryl,
Do you know how much it will take to clean it up? That's the important part. I don't think you can go more than 30 over. FFT, (food for thought) If you needed it done again somewhere down the road, you may not have enough left for another clean-up. Just a thought:)
Dan
Mike Van Veghten
07-15-2006, 06:39 PM
Two things -
1. The shop doing the work is reputable?
2. Bearings available?
If those two are a yes...no problems with the .030" under. Though I probably wouldn't go any further thAn .030".
07-15-2006, 08:56 PM
Std thru .030 are readily available. I don't know that I've ever SEEN .040 or larger for a Stude V8.
But .030 is OK.
Alan
07-15-2006, 10:00 PM
A not too rough .010/.010" 289 crank is a find, grab it if it isn't more than $100-150. You can do a number of things to it, turn it to 20/20 and if it won't clean up there you can have it hard chromed. Build it back up to Std. and have it reground. I have tried to have 30/30 cranks chromed and it is too much to build the chrome gets holes in it.
