View Full Version : Transmission, What is this?
5859
07-08-2006, 10:49 PM
On my 58 flightomatic, it is a long bolt that is located next to the fluid level dipstick/filler, and is bullet shaped on the end that goes into the transmission, it looks like oil runs against it and it has a lock nut to adjust it further in or out of the trans. It reminds me of a large fuel/ air adjustment on a carburator. What is it and how should it be adjusted?
ROADRACELARK
07-08-2006, 10:54 PM
This is one of the band adjustment bolts. It has a critical adjustment. Refer the shop manual for correct procedure.:)
Dan
5859
07-09-2006, 01:01 AM
Do you know if it is the reverse band adjustment?
07-09-2006, 04:32 AM
According to the oil flow chart and the "operation description" in the Stude. Repair Manual the band adjustment bolt & lock nut on the outside of the case does adjust the rear band, it is in use in Low and reverse.
Studebakers Northwest
Ferndale, WA
