View Full Version : torque specs
dclewallen
07-03-2006, 05:03 PM
I don't have access to my shop manual right now, so can anyone provide me with the torque specs for the main and rod caps on my 232? Thought I'd plasti-gauge them to check wear. Thanks,
Darryl C. Lewallen
N8N
07-03-2006, 05:10 PM
80 ft-lbs IIRC for the mains. Don't remember the rods.
62 Daytona hardtop
dclewallen
07-03-2006, 05:11 PM
Thanks, I also need the crank end play.
Darryl C. Lewallen
Alan
07-03-2006, 08:06 PM
Rods 52-54 Lbs. Ft.
Mains 88-93 Lbs. Ft.
End play .003-.006"
dclewallen
07-04-2006, 08:15 AM
Thanks for the help, I appreciate it.
Darryl C. Lewallen
Alan
07-04-2006, 02:25 PM
And I should have said that that is with 30 weight oil on the threads and under the bolt or nut heads. Those are Stude specs and were from the 50's. If you use molly grease or some of the new assembly lubes you have to adjust the specs accordingly to the manufactures tables.
