View Full Version : polarity/grounding
jkeinert
06-28-2006, 05:06 PM
1955 and prior had 6 volt systems, I believe?? IN those systems, is the positive battery terminal connected to the car frame(where the ground/negative would usually be)--opposite of what is typical in 12 volt systems??
N8N
06-28-2006, 05:31 PM
yes, at least in Studebaker-land, the switch from positive to negative ground occurred at the same time as the switch from 6V to 12V.
62 Daytona hardtop
jkeinert
06-28-2006, 05:41 PM
So does that mean that in a 55 Stude, the positive terminal on the 6 volt battery should be connected to the frame, and the negative battery terminal gets connected to the (other)wiring??
62 Daytona hardtop
06-28-2006, 05:51 PM
Yes;)
glen
06-28-2006, 05:52 PM
J
Yes, my 1953 sedan actually has the pos connection
grounded to the engine block and the Neg side goes
to the wiring...So your 55 should be pos. grounded
to the frame, if that is the location for that year.
Hope this answers your question
Glen Brose
53 Champion 2 dr Sedan
rockne10
06-28-2006, 08:27 PM
The groundstrap+ in my 51 is connected to the top left water manifold bolt.
