View Full Version : 6 vplt to 12 volt inverter
55Prez
06-11-2006, 08:53 AM
Did someone recently post a URL for a site that sold 6 volt to 12 volt inverters?
thx
52hawk
06-11-2006, 10:45 AM
Try jc whitney? They have a searchable website,but at quick glance I didn't see any 6-12 volt inverters.I know little about electrical,can 12 be had from 6?? I know there are reducers for say,12 volt to 6 volt..
LaSalle,Il
61Hawk
60Lark
whacker
06-11-2006, 01:07 PM
I don't know about 6 to 12 volt inverters, but if you go to this website:
http://www.reconnsworld.com/power_voltdoubler.html
you can get a schematic for a voltage doubler using an IC555 timer that can be used to power low amperage 12 volt stuff in your 6 volt car. Unfortunately, it won't work for the magnetic clutch on an air conditioner compressor. It can be used for things like an electric fuel pump or a fan in the air conditioner or heater. Or you could run your cell phone charger. What are you planning?
starlightchamp
06-11-2006, 03:39 PM
Hi 55 prez
Try www.powerstream/dc6-12.htm
They have invertors up to 15 amps and 30 amps. 150 watts.
Probably run what you want .
Starlightchamp
50 starlight
63 hawk
garyash
06-11-2006, 10:11 PM
Here are a couple more sources for inverters:
http://www.antiqueautomobileradio.com/productsF.htm
http://www.pressenter.com/~cmeyer/index.html
Gary Ash
Dartmouth, MA
'48 M5
'65 Wagonaire Commander
'63 Wagonaire Standard
www.studegarage.com
64V-K7
06-12-2006, 07:34 AM
Thanks to all for the responses. I'm going to fit a 12V radio/cdplayer to the 55 for long distance tunes
studegary
06-12-2006, 10:32 PM
For that application, you will want an inverter/converter. Remember, besides going from 6 volt to 12 volt, you also want to go from positive ground to negative ground. I have one here that I used in a '53 in the '70s (for a 5 watt cb radio). I paid $35 for it then and would sell it for that much now (plus shipping). It is an E. F. Johnson Co. unit, P/N 239-0120-002 and it is Made in USA. I mounted it up behind the dash, out of sight. Maybe you can find something locally, or cheaper, to do what you want.
1959 DeLuxe pickup (restomod)
60Lark
06-13-2006, 12:42 AM
Gary,
If 55Prez does not want to buy your converter, I will buy it.
Studebaker Fever
60 Lark
51 Champion
Phil
64V-K7
06-13-2006, 08:25 AM
I'll be taking Gary up on his offer.... :-)
64V-K7
06-13-2006, 08:26 AM
I'd like to take Gary up on his offer ... :-) thanks
curt
06-15-2006, 08:29 PM
Invertor and converter combos are not easy to come by from my past experience.
