View Full Version : Drive shaft won't slide in
studeclunker
08-29-2006, 01:04 AM
I have nearly put my '63 wagon back together.:D One of the last chores is to get the drive shaft on. And it won't.:( the yoke slides into the transmission extension housing only a quarter of an inch and won't budge any further. I don't get it.[?] The shaft came out rather stiff as well. I just can't seem to get it to cooperate. I don't want to force things. That's when they break...[}:)]
Any suggestions?[8)]
Lotsa Larks!
Ron Smith
sbca96
08-29-2006, 02:47 AM
Try wiggling it a little, but check inside the yoke for any corrosion.
Tom
08-29-2006, 03:20 AM
It sounds like it's going into the seal (soft) and NOT into the bushing, (Harder) requires the yoke angle to be more accurate. Remember the engine and trans are tilted down in the rear. And of course, if the Wagon is a Wagonaire the "X" member keeps you from seeing anything![xx(]:(
Studebakers Northwest
Ferndale, WA
CHAMP
08-29-2006, 07:26 AM
Lubrcate the yolk shaft inside and out with WD-40 or other light oil.:)
CHAMP
08-29-2006, 07:31 AM
Check the splines out very closly both the trans. and inside the yoke.:)
bams50
08-29-2006, 01:23 PM
...and check for a master spline!
Parish, central NY 13131
studeclunker
08-29-2006, 05:58 PM
Suderich, I have no idea what you are talking about. The yoke is lined up on the spline and it wont go onto it more than a quarter inch or so.
The idea of a master spline is interesting. Though the manual doesn't mention anything. In fact, the manual has very little to say about this.
Chevy has a seal that pushes onto the spline, does Studebaker? The book doesn't mention it. When I took the engine out there was a great deal, in fact the majority, of the transmission oil coming out the spline. Is this normal? When operating, the transmission looses almost no fluid. It's one of the least drippy trannys that I've ever had.
Everything is so greasy I just don't see how it could corrode. Still, I'll try the WD40. Love the stuff! I buy the BIG cans. LOL!:D
Lotsa Larks!
Ron Smith
N8N
08-29-2006, 06:09 PM
there is some play in the output shaft when the yoke is not inserted. You might have to wiggle it a little to get it started into the bushing (the bushing on the yoke actually provides support for the output shaft.) I am not aware of any Stude xmission that uses a master spline on the output shaft but I'm willing to be corrected.
This can be a PITA if you've just replaced the front u-joint. the stiffness can fight you a little.
good luck,
Dwain G.
08-30-2006, 12:11 AM
Yes, plenty of fluid will leak out when the transmission is tipped down at the rear with the driveshaft removed. The yoke riding in the seal is what keeps the oil in. The rear bore of the yoke is sealed with a soft plug or fluid would leak there also. On occasion a compression of air inside the yoke will occur when you try to push it onto the mainshaft. Are you feeling/hearing a 'clunk' when it stops, like it's hitting the tailhousing bushing, or is it more of a 'soft' stop?
http://home.comcast.net/~jdwain/9GQ2.jpg
Dwain G.
studeclunker
08-30-2006, 02:14 AM
Interesting... so the front yoke keeps the tranny fluid in? You know, I looked at the manual and it recommends lubricating the front yoke (the assumption being the inside?) and the transmission tail shaft with S.A.E. 90 Standard and Overdrive or Type A (AQ-ATF) Flightomatic Transmission... So since this is an automatic transmission I should lube it with auto tranny fluid? Trust me, it's soaked already.
B.T.B. Dwain? There's no sound, really, except my cussing (just kidding). It just won't move. The front yoke isn't into the tailshaft housing enough to create any kind of seal.
Lotsa Larks!
Ron Smith
buddymander
08-31-2006, 02:49 PM
Somebody musta snuck in your garage and switched yokes on ya!! I hate when that happens!
John Kirchhoff
08-31-2006, 05:03 PM
I remember once when I had a little difficulty getting the yoke to slip over the output shaft on a manual transmission. Ends up the shaft was turning right along with the yoke when I'd rotate it. I put it in gear to keep the shaft form turning and that cured it.
studeclunker
09-03-2006, 01:42 AM
Well, I tried most of the above and then jacked up the tail of the tranny just a little. There isn't much room down there, but 1/2 inch is all I needed aparently. It took a bit of wiggling, and she finally slid in.
Whew![xx(] What a pain in the... Well, anyway.
All I have to do now is get the brakes done and find a way of keeping the powersteering hoses from rubbing against the manifold/exhaust pipes.
I'm really looking forward to driving this car. It's a Daytona wagon and, though a little beat up, in good condition. Just a nice car all 'round.
Lotsa Larks!
Ron Smith
