View Full Version : Timing for Studebaker Lark
imported_n/a
05-25-2006, 05:58 PM
I have a 1960 Studebaker Lark 6 with a 170 flat head 6. The timing is off. I replaced the distibuter cap and rotor. And all the spark plugs are in order. And it still wont start. It has a great battery, it is putting gas into the carb. And it spins great and it sounds like it will start but it wont.
Any ideas?
05-25-2006, 06:22 PM
Is this the car where you confirmed #1 position on the cap by using the timing mark on the harmonic balancer?:)
kmul221
05-25-2006, 08:26 PM
If the 6cyl. is the same as a V/8 per TDC the rotor could be 180 dgrs. out.When the crank marks & the needle indicate TDC make sure the rotor is pointing at #1 not 180 away.The rotor in a V/8 turns counter clockwise maybe the 6 is the same,keep this in mind when placing the ignition wires in proper order in thr dist.cap
buddymander
05-26-2006, 01:15 AM
turn the distributor one way a little bit and try it. If it sounds less promising, then try the distributor the other way a little bit.
