View Full Version : Quick solder question
Eman
05-25-2006, 05:28 PM
I just got the pigtails for my taillights and need to attach the little copper (or brass?) contacts to the end of the wire in the socket. Is there a certain type of solder I should or shouldn't use? Rosin vs acid?
Thanks.
1951 Commander Starlight Coupe (aka "Stella")
www.bulletshots.net
www.bulletshots.net/blog
www.alabamastudes.com
05-25-2006, 06:20 PM
Use rosin core. Acid core will work against electrical applications over time! Use some good flux too.;)
Soldering isn't as easy as it looks (done right anyway). I was NASA spec certified for soldering, back in my aircraft electrician days. Anyone can do a passable job of soldering with a little practice. The biggest mistake made is cold soldering. If the solder has a "rough" look to it once it cools, it's not a good joint. It must have a shiny appearance to it once it cools.
Get the pieces to be soldered thoroughly up to temp, apply just enough solder to make a good bond and then be EXTRA careful NOT to move the joint until it sets. Moving the joint before it sets up is the PRIMARY cause of cold solder joints.;)
05-25-2006, 06:43 PM
Use rosin core solder with wire. Acid core and flux are for metal and plumbing. Acid will corrode the wire.
I use small diameter rosin core from Radio Shack, .032 60/40, #64-009. Their 40W pencil iron is great for the price, and has replacable tips, #64-2071. A stand and an assortment of tips for the iron are a good idea.
Mike M.
Eman
05-25-2006, 07:00 PM
Thanks again guys!
www.bulletshots.net
curt
05-25-2006, 09:32 PM
High tin content,lower lead content in the solder,is excellent. Also, a mechanical lock is most desirable, then the solder holds the joint and the solder is not the total joint. Make sure all contacts are bright shiney metal , then flux heavy and heat as discussed above.
Jeff_H
05-26-2006, 06:56 PM
If you find some and have a choice, get some 63/37 "eutectic" solder. Unlike the 60/40, it does not have a "soft" state, its either liquid or solid. A lot less likely you will get a cold solder joint trying to hold things still with shaky hands waiting for it to cool ;)
Jeff in ND
'53 Champion Hardtop
