View Full Version : head gasket sealant
Ron Dame
05-18-2006, 05:19 PM
Popped the head gasket on my OHV6, and am close to ready to install the new one. There's a bit of a nick in the block deck where the hole occurred between #3 and #4, but since it was low on compression anyway, I'm going to button her up so I can drive her until I get theBlack Bart Special (185 OHV 6) built.
I haven't done a head gasket in 20 years or so, and have forgotten...What's the best sealant to use ( Or not use) with a head gasket?
Ron
Ron Dame
'63 Champ
JDP
05-18-2006, 06:51 PM
Permatex copper coat spray.
Studebaker News Group
64 Daytona HT
64 R2 4 speed Challenger
63 R2 4 speed GT Black
63 R2 4 speed GT White
63 GT Hawk
63 Avanti
62 Daytona HT
53 Coupe
Ron Dame
05-18-2006, 07:18 PM
[quote]Originally posted by JDP
I still have some permatex copper coat in a brush-on can that's not all dried up. That's what I was thinking,and you've copnfirmed it as OK..sort-of. Brush it on the gasket. So do I let it set up, or put it on "wet"?
Ron Dame
'63 Champ
JDP
05-18-2006, 07:56 PM
Let it "tack up".
64 Daytona HT
63 GT Hawk
63 Avanti
62 Daytona HT
53 Coupe
BRUCESTUDE
05-18-2006, 11:40 PM
Permatex copper coat works great!
tomnoller
05-19-2006, 08:10 PM
Ron, I've known guys who've used JB Weld on head decks with minor dings and had good results.
BobPalma
05-19-2006, 10:40 PM
Ron Dame
'63 Champ
:) RON: OK to use old Copper-Coat, but be sure you mix it up thoroughly! The ball rolling around isn't sufficient if you haven't used it for awhile. Take out the little dauber and mix it up with a screwdriver. ;) BP
r1lark
05-20-2006, 09:51 AM
Well, just to be different <G>, I use KW CopperCoat, basically the same thing as Permatex.
(Back in the 'old days' [the 'early '70s, I'm not THAT old<G>], we used aluminum spray paint, because it was cheaper. That was back when aluminum spray paint actually had aluminum in it. Nowdays, don't do this, the aluminum paint is just aluminum color.)
Do like JP said....let it tack up some before installing. I usually spray several thin coats on both sides of the gasket, let it tack up, and then install/torque.
Paul
Visit The Studebaker Skytop Registry website at: http://hometown.aol.com/r1skytop/myhomepage/index.html
Ron Dame
05-20-2006, 05:24 PM
There's a ball in there? It sure is stuck good!
All is back together, and she;s running as good as she ever could..given that the *best* cylinder has 95 psi compression!
Ron Dame
'63 Champ
Ron Dame
'63 Champ
sbca96
05-22-2006, 12:11 PM
As usual I disagree, we tried that coppercoat stuff years ago when we
built my brothers engine, & blew two headgaskets one after the other.
Prior to that we had used an old engine builder trick of smearing some
axle grease on the block, and then on the top of the gasket. This also
makes cleanup MUCH easier when you DO have to take the head off again.
Apparently the theory is that the grease will ooze into the combustion
chambers and then once the engine fires, it creates a carbon ring at
the gasket. The coppercoat stuff tends to be difficult to get an even
coat and can cause leak paths. Never had an engine blow a head gasket
with the grease trick, and my Hawks engine was and average of 182 psi
on a cold compression test (about 9.3 compression). Redid my brothers
engine with the grease, & that was over 10 years ago including a trip
across country towing a trailer with 3:73 gears.;)
Tom
1963 Studebaker Avanti (http://hometown.aol.com/sbca96/images/63avanti.jpg), 102,000, custom made brake brackets to mount 1998 Mustang GT 4 wheel disc brakes (soon to get 13" Cobra front brakes, 2003 Mustang Cobra 17" wheels, GM altenator, will be getting : 97 Camaro Z28 tan leather seats, 97 Camaro Z28 T-56 6-speed trans, Ported 'R3' style Avanti heads with stainless full flow valves, 'R3' 276 duration cam w/chrysler solid lifters, shortened push rods, aluminum cam gear, Edelbrock AFB Carb, GM HEI distributor, 8.8mm plug wires, waiting in the garage.
