View Full Version : Engine: Oil flex tube- where?
valleyguy
03-21-2007, 02:15 PM
I remember reading a comment in a recent post about
the the need to replace the oil line running from the block to (oil pressure gage?), which can fail due to wear/age, causing loss of oil and engine failure. It's not listed/shown in my manuals.
Just where is this line located? I have a hard type line running from the right side of the block on my V8 through the firewall, which I assume is the line in question ... but the line found listed in SI ("oil flex line"), is a rubber flex one, rather short.
Just what should I be replacing? tks,
Joe D.
41 Frank
03-21-2007, 02:24 PM
It is a rubber line that comes off the back of the right cylinder head and attaches to the metal line going through the firewall on a V-8 about 6 inches long. Someone may have modified the line and eliminated the rubber hose at some point if you don't see it.
BShaw
03-21-2007, 03:16 PM
Right after I got my Hawk I heard about the flex hose and a visual inspection looked good... right before it gave up the ghost and spewed Rotella all over the engine compartment! Now I carry a spare...right next to an extra fuel pump.
BShaw,Webmaster
http://i61.photobucket.com/albums/h53/StudeRobert/StudeWebService-small.gif
60 Hawk. 49 2R5, 39 Champion
Woodbury, Minnesota
03-21-2007, 04:35 PM
I've grabbed ahold of them to see how much flexibility they still have - only to have the SNAP at my touch![xx(][xx(][xx(][8]:(
Miscreant adrift in
the BerStuda Triangle
DEEPNHOCK
03-21-2007, 04:37 PM
You know...
I don't think I have ever succesfully removed one to inspect it.
I have broken them all...
(Maybe it's just me;))
BShaw,Webmaster
http://i77.photobucket.com/albums/j54/deepnhock/Jeff%20Rice%20Studebaker%20Pictures/1937StudebakerCoupeExpressJeffRicee.jpg
DEEPNHOCK at Gmail.com
Brooklet, Georgia
'61 Hawk (project)
Eman
03-21-2007, 05:01 PM
You can kind of see mine to the left of the disconnected accelerator linkage (passenger side of the distributor), running down near the firewall.
http://farm1.static.flickr.com/131/422745074_5a5126cbe0.jpg
Hope this helps.
[img=left]http://www.bulletshots.net/images/stella3.jpg[/img=left]1951 Commander Starlight Coupe (aka "Stella")
www.bulletshots.net
www.bulletshots.net/blog
www.alabamastudes.com
bradnree
03-21-2007, 07:47 PM
My flex tube burst last week on a '52 Stude V8 and I thought that the engine really blew this time. The tube was very old but looked good and lasted for about 60 minutes of run time...........Brad
bondobilly
03-21-2007, 07:49 PM
The one in my 47 Commander Coupe let go mid-span of the Tappan Zee Bridge. I tied up traffic for over 90 min.
BG
garyash
03-21-2007, 09:03 PM
Do not buy an NOS oil line. Get a NEW one from a Studebaker vendor. Oil- and oxygen-resistant rubbers are much better now than 50 years ago.
Dartmouth, Mass.
'48 M5
'65 Wagonaire Commander
'63 Wagonaire Standard
John Ratliff
03-21-2007, 09:31 PM
There is another flex line you should replace as well. That runs from the oil filter canister to the oil fill tube. If you have a full flow filter or no filter then disregard this line. Mine looked very good but had a crack at the fitting. When I went to remove it it just fell apart.
John Ratliff
http://static.flickr.com/102/302372902_63249ab71a_m.jpg
sbca96
03-22-2007, 02:09 AM
Yup .. we had one break on my brothers 1964 Daytona, it emptied the
crankcase in just a few seconds. If you dont want to carry a spare,
you can at least bring a pipe plug.
http://hometown.aol.com/sbca96/images/R1_engine/R1_007a.jpg
Tom
valleyguy
03-22-2007, 03:50 PM
Well, mine has been modified at some point, there is no rubber flex line, all hard line.
Wonder what the implications are since there is nothing to absorb engine vibration; should I
replumb this thing? Tks for the tip on the oil line from the oil filter as well; I'll
change that one. Joe D.
R_David
05-20-2014, 03:54 PM
Glad I saw this thread, mine is also a hard line. Probably replaced by the guy who rebuilt the motor 20 years ago. I too wonder if there will be a problem for me in the future having a hard line going straight from the block to the oil gage. Haven't had any problems yet...
BobPalma
05-20-2014, 04:32 PM
:oops: YIKES! :eek::QQ:
Under NO, repeat NOcircumstances should you have a hard line from the engine block to the oil pressure gauge feed line on the car's cowl. It's astonishing that it hasn't broken yet.
Jim Turner of Turner Brakes now markets replacement oil pressure engine-to-cowl flexible hoses in stainless steel with a black covering, so it looks like OEM "rubber" hose. These are a permanent investment because they will literally last the life of the car. he has them available for both six and V8 engines. :D BP
rockne10
05-20-2014, 07:44 PM
Motor mounts, radiator and heater hoses, fuel lines, vacuum lines, oil pressure lines; there is a logical physical reason why any motionless items associated with the body or frame are attached to the engine with a flexible connection.
The original type oil pressure hoses are still widely available and a spare should be carried or, as Tom said, at least a pipe plug.
Use one of Jim Turner's stainless replacements and you should be good for as long as internal combustion is still legal.
R_David
05-20-2014, 09:04 PM
Thanks for the tip guys!! Sounds like a great fix.
rockne10
05-20-2014, 11:24 PM
Did whoever replaced that line leave the requisite fitting on the copper tube to return it to stock? If not, you will need a new fitting.
52 Ragtop
05-20-2014, 11:43 PM
Yep, I have the oil flex line in black braided stainless, with the correct fittings available, as Bob stated, both 6 &8's. I can also now make up the 2 oil lines that go to the oil filter canister, just need the correct lengths. These too are a braided stainless steel covered in black.
Jim
