View Full Version : Door switch problems
Champion51
05-07-2006, 07:28 PM
I know very little about wiring. Can anyone tell me what would cause a clicking sound from the ammeter gauge when I open the back door?
When I open either front door, the pillar switch activates properly and the map light come on. However, if I open either of the two back doors and the switch button pops out, the light does not come on and I hear a very distinct click from the the dash (I believe the ammeter gauge). The ammeter dial jumps back temporarily to the discharge side of the instrument and then up again. The clicking sound is evenly timed about two seconds or so apart. The door switch gets quite warm to the touch. As long as the doors are closed everything is fine.
I have had the dash out to restore and back in again, but I am sure I have everything wired properly as I was quite careful in labelling lines, and recording the disassembly with camera and charts. I do not have the dome lamp installed or the pillar switch hooked up. But this didn't seem to affect the rear door switch operation in the past, prior to removing the dash.
It's my guess it may need a resistor in the line such as the dome lamp install with a bulb in place. Its obviously getting juice, but too much. Am I right?
Dave D.
'51 4-dr Champion
Smithers, B.C.
Canada
N8N
05-07-2006, 07:31 PM
You've got a dead short to ground somewhere in your dome light wiring. sounds like the rear door switch wire was inadvertantly connected to +12V rather than the ground side of the dome light and therefore is causing a circuit breaker to trip whenever you activate either of the rear pillar switches. I would have a look see in the area of the dome light itself; I have to admit I've never worked on a 4-door Stude but I am guessing there's a wire up there landed on the wrong terminal.
good luck,
62 Daytona hardtop
05-07-2006, 10:05 PM
N8s nailed it. I'd guess there's a short between the wire from the door switches (all they do is provide a ground) and the hot wire in the dome light fixture. I'd be looking for a goof in the dome light fixture itself!;)
Champion51
05-08-2006, 03:10 PM
Nate and Bob. You guys were absolutely right!:D The red and black wires had been unbared and were touching each other out of sight only a few inches from the dome light fixture. Thank you, thank you!! No more clicking!
If anyone else has this model ('51 Champion), could you confirm, does the dome light only come on when a back door is opened or when activated by the pillar switch? From how I read my wiring diagram, this would be the case. Although I thought originally it came on with the light switch or an open front door.
Dave D.
'51 4-dr Champion
Smithers, B.C.
Canada
rockne10
05-08-2006, 08:06 PM
I believe it's also activated by the headlight switch; rotate left for dome light, right for dash lights.
N8N
05-08-2006, 08:59 PM
can't help you, haven't worked on one of those and don't have a manual. I would assume that the front doors would have switches for the dome light but can neither confirm nor deny these allegations.
62 Daytona hardtop
chocolate turkey
05-08-2006, 10:48 PM
Just finished a complete re-wire of a 51 Commander 4 dr. It has door switches on all four doors and all work as any other Stude door switch. Open any door to have the map light come on.
Brian
Brian K. Curtis
Dwain G.
05-08-2006, 11:42 PM
Dave D.
'51 4-dr Champion
Smithers, B.C.
Canada
Dwain G.
Dwain G.
05-08-2006, 11:49 PM
You are correct. On a 4dr car the dome light only comes on automatically when the rear doors are opened. A manual switch is located on the right door post.
The map light (just under the roll of the dash) should come on automatically when the front doors are opened. It can also be controlled by turning the headlight switch to the left.
Dave D.
'51 4-dr Champion
Smithers, B.C.
Canada
Dwain G.
60Lark
05-11-2006, 12:44 AM
I agree with Dwain G. :) dome light comes on automatically when rear doors are opened or manually by the switch on the right pillar. Map light on the dash comes on automatically when the front doors are opened or manually by turning the headlight switch to the left. [8D]
Studebaker Fever
60 Lark
51 Champion
Phil
