View Full Version : '64 Sedan signal light clicker
sumf
03-20-2007, 06:08 PM
My signal light stopped working.
I found the HD can on the floor - I had put that one in as the clicking was weak to thses old engine-damaged ears.
My hearing is weak, I have been told, as is the flashlight.
Where the hell is the socket for the clicker-can, anyhow?
Karl
03-20-2007, 06:16 PM
When you find the socket, Karl...try one of these...
http://www.turnalarm.com/
http://members.aol.com/pclchc/EL98.htm
sumf
03-20-2007, 06:55 PM
Thanks, Dick.
In England, I got two 12 vt buzzers (from a house alarm system) and wired one to each wire going to a front signal bulb. (I could have used one buzzer and two diodes.)
They were a bit too loud so I put an extra layer of double-stick foam between the buzzers and the panel they were taped to. As there was a sound difference between them, I even knew if it was the left or the right that was on.
I have relatives who might be able to use such things, too!
Karl
03-20-2007, 07:50 PM
PLEASE SEE SAME POST ON GENERAL STUDE. DISCUSSION, problem solved!
Studebakers Northwest
Ferndale, WA
