View Full Version : regulator
tlakeusa
04-30-2006, 07:02 PM
I am hoping that installing a new regulator on a 6volt positive ground system is just a simple straight across job..... is it ?
JDP
04-30-2006, 07:39 PM
It's easy, just mount it, hook the wires back uo correctly and polorize the generator.
64 R2 4 speed Challenger
63 R2 4 speed GT Black
63 R2 4 speed GT White
63 Avanti
54 3R Pickup
52hawk
04-30-2006, 08:03 PM
How bout a refresher course on the polarizing? Is it field to ground? Do you need to polarize if the battery has been unhooked for a few days?
I'm asking about a 12 volt neg ground system,though.
LaSalle,Il
61Hawk
60Lark
JDP
04-30-2006, 08:36 PM
Make a short jumper wire to short between the battery (B or bat) and generator (G or gen) lugs on the voltage regulator. Only a split-second or a spark is required, so just tap your jumper wire onto the lugs and pull them right back off.
63 Avanti
54 3R Pickup
rockne10
04-30-2006, 08:50 PM
Polarization is only required if you have a generator, not an alternator. If you have a generator, you should polarize anytime and everytime you disconnect power. Otherwise you stand a 50/50 chance of getting it right.
tlakeusa
05-01-2006, 10:26 PM
A second thought, not related to regu;ators and the like. My 48 went on the freeway for the first time yesterday and I wasn't sure how hard to push the car. Meaning that at about 60 mph the revs sounded pretty high. So I drove about 5 miles right around 60 w/o out attepming 65 . Is 65 advisable or is 60 to 55 mph the proper speed ? By the way the regulator works great ! 48 Land Cruiser six with 3 speed & OD
rockne10
05-01-2006, 10:44 PM
Commander six or Champion six? Three-speed or three w/OD?
studebakerkid
05-02-2006, 06:38 AM
Shoot on occasion I used to run the 54 up to 90 with that flathead and OD engaged and it had 4.88 differential gears.
65 2dr sedan
64 2dr sedan (Pinkie)
61 V8 Tcab
61 Tcab 20R powered
55 Commander Wagon
54 Champion Wagon
46 Gibson Model A
05-02-2006, 10:43 AM
As long as your overdrive is working, higher speeds shouldn't be a problem.;)
studegary
05-02-2006, 02:12 PM
He stated that it is a "Land Cruiser", so that would be the larger ("Commander") six. He also stated that it has "od." Sorry, I see that he may have edited answers to your questions into his original question.
If you are in overdrive and the rear axle ratio is the original one, I see no problem with 70 to 80 mph, if you feel comfortable with the car's handling and braking systems. What's your hurry <G>?
1959 DeLuxe pickup (restomod)
tlakeusa
05-02-2006, 05:17 PM
My Land Cruiser has the standard "Big 6" for that model. Don't mean to be a nervous nellie, just don't want to do something stupid and expensive. BTW how about a quick break down on gear ratios . I am guessing the higher the ratio the easier the transfer of power through the 3rd memeber ?
rockne10
05-02-2006, 11:11 PM
Watch the oil pressure and keep the oil clean,
The 48 Land Cruiser is a highway machine.
