I have a 60 hawk with a 289. I went out to crank her up and just listen to her for a while but she did not want to play. I would hit the switch it started let go of the switch and it shut off. Well after much head scratching I broke out the service manual and found the wire. I do not have an external ballast unit so I jumped the wire out and she ran. OK found the problem to be the pink ballast wire that runs from the coil to the switch.
Question is does anyone know where or if there is a replacement wire for this? Any help would be great[?]
